did any Indian GP`s have bolt in fork buffers ?
Postby martyn dwane » Thu Jul 31, 2025 4:27 pm
I have an Indian (SIL) Gp200 that has bolt in Fork Buffers , is this usual ?
would have thought they were Push in like Italian GP`s.
martyn dwane
Re: did any Indian GP`s have bolt in fork buffers ?
Postby Toddy » Thu Jul 31, 2025 6:39 pm
Is it an early Indian GP ?
Postby hullygully » Fri Aug 01, 2025 9:35 am
have the forks being drilled laters?
Postby martyn dwane » Fri Aug 01, 2025 11:32 am
Toddy , yes it is.
Hullygully, no i dont believe it has.
martyn dwane
Postby jonoy » Fri Aug 01, 2025 3:48 pm
Probably been drilled as even late SX models had
push in fork buffers.
jonoy
Postby Fast n Furious » Fri Aug 01, 2025 11:55 pm
Sometimes, the retaining clip that holds the GP style buffers in place can rot out resulting in them being drilled out to accept bolt-in ser3 buffers, which can be a tricky job to get them spot on in the right place. (it usually results in ovalated holes :o ). If you remove the buffers and inspect internally you can usually see remnant traces of the old clip if this is the case.
Unlike early Ser2 forks, Ser3 forks have one of the 2 buffer bolts on each fork boot sitting in a recessed part of the seam for the bolt head. This recess isn't there on GP fork boots further supporting that they have likely been drilled out.
Alternatively............ maybe someone has grafted a Ser3 fork tube onto a GP fork stem? (check the welds here) :!:
Postby martyn dwane » Mon Aug 04, 2025 11:30 am
spoke to Rayspeed and they concur with F&F & Hullygully.
martyn dwane
