MB adjuster block cable routing
Postby mm man » Sat Feb 08, 2025 10:12 pm
Just fitted a MB gear and clutch adjuster block to my S3 but if I route all the cables under the engine mount the clutch cable doesn’t align very well also the inside gear cable isn’t great . What’s the best route for the cables when using one of MB blocks .
Thanks.
mm man
Re: MB adjuster block cable routing
Postby Dom » Sun Feb 09, 2025 8:02 am
I have one of these on my scooter , I ran the gear cables under the mount and the clutch over the top
Dom
Postby mm man » Sat Feb 15, 2025 8:04 pm
Thanks Dom I was out in garage today and had another play with the cable routing and agree with you that this set up seems to work best .
Thanks for your time and imput.
mm man
Postby gaz_powell » Sun Feb 16, 2025 9:04 pm
Is it the newer MB block?
Ive just cabled up using of the older blocks and ended up gears the front of engine mount and clutch to the rear but not over the top.
Postby mm man » Tue Feb 18, 2025 10:25 pm
This was a new block brought from MB a couple of weeks ago
mm man
