by LambrettaMarky » Thu Feb 06, 2025 12:06 pm
Folks
Should the rear brake cable run up and over the engine mount or inside it and closer to the cylinder cowl?
Thx
LambrettaMarky
by missing lynx » Thu Feb 06, 2025 2:58 pm
It should route along the cowl and along the top of the engine, not over the engine mounts and In as straight a line as possible and don't forget to use the clip by the cable adjusted block.
by LambrettaMarky » Thu Feb 06, 2025 3:19 pm
missing lynx wrote:It should route along the cowl and along the top of the engine, not over the engine mounts and In as straight a line as possible and don't forget to use the clip by the cable adjusted block.
Thank you!
LambrettaMarky
