Ferrules or No ferrules
Posted:
Sun Jan 26, 2025 12:43 am
by mm man
Do you fit a set of ferrules (top hat) onto the clutch and front brake cables at the lever end in the headset or do you just set the cables against the slot in the headset .
Re: Ferrules or No ferrules
Posted:
Mon Jan 27, 2025 10:42 am
by martyn dwane
just in the slots. doubt if a top hat of any kind would fit.
Posted:
Mon Jan 27, 2025 3:03 pm
by Warkton Tornado No.1
Just for the record, Lambretta outer control cables always have a ferrule fitted at either end. If the slotted housings at the headset are too tight to allow the ferrules to fit, they can be - carefully! - widened by a screwdriver prising open the slot to suit.
