Ferrules or No ferrules
Postby mm man » Sun Jan 26, 2025 12:43 am
Do you fit a set of ferrules (top hat) onto the clutch and front brake cables at the lever end in the headset or do you just set the cables against the slot in the headset .
mm man
Re: Ferrules or No ferrules
Postby martyn dwane » Mon Jan 27, 2025 10:42 am
just in the slots. doubt if a top hat of any kind would fit.
martyn dwane
Postby Warkton Tornado No.1 » Mon Jan 27, 2025 3:03 pm
Just for the record, Lambretta outer control cables always have a ferrule fitted at either end. If the slotted housings at the headset are too tight to allow the ferrules to fit, they can be - carefully! - widened by a screwdriver prising open the slot to suit.
Users browsing this forum: Baidu [Spider] and 84 guests
