by GExS » Fri Jan 03, 2025 10:04 pm
The throttle and gear cables do not fit into the outer cable guides in an Italian GP headset!
GExS
by Warkton Tornado No.1 » Sat Jan 04, 2025 3:10 pm
Do they not fit by much? No doubt you are aware that by carefully opening up the slot in the cable housing via a screwdriver flat blade, the holes can be widened….
by Storkfoot » Sat Jan 04, 2025 3:43 pm
Will Vespa top hats fit the cable outers?
Have you measured the SIP cable ends against another set? If so, is the diameter much thicker?
by GExS » Sun Jan 05, 2025 7:36 pm
After much messing about, slightly rimming out the inner stock and gently widening it, I’ve managed to squeeze them. What a carry on.
GExS
Users browsing this forum: No registered users and 92 guests
