Storkfoot wrote:Yes, you do need to fix it. Your exhaust is not functioning as it should. It sounds like when the silencer is fitted, it is pulling at the u-bend. Usually, the remedy is to take a cylindrical file or dremel to where the silencer fits to the engine casing.
What cylinder do you have?
L111amo wrote:I don’t see where it fits the body of the block would cause this, ?
… You can’t adjust the ubend, without great difficulty, but you can adjust the silencer fit to the engine casing. It’s not ideal but you haven’t got much choice, other than sending it back….
L111amo wrote:Generally some decent exhaust paste should fill slight gaps at the joint, just let it go off before starting it up or it will blow out
