missing lynx wrote:I don't use the junction box I just wire direct from the engine to the cdi and the regulator. That way you remove a potential failure point
citydaz wrote:I used a small electrical connector box from amazon - about £4.
Inside i put the wires to be connected using household electrical terminal blocks.
The box i glued and cable tied to a small piece of acrylic (an old chopping board sprayed black).
The acrylic plate I bolted through the hole in the outboard arm.
Job done - looks really neat compared to the standard GP rubber boot arrangement.
