Front Disc Brake Problems
Hi,
Ive finally finished rebuilding my 150dl and have been taking it for a few short trips around the quiet back roads of Cheshire to run it in.
The problem is the very poor front disc brake. After paying top dollar for an Italian remade hub and many problems with the vendor - it being sent back 3 times for rectifications I have set it up and the main problem is that the actuator arm doesnt seem to want to spring back on release of the brake lever. This means that the brake "sticks on" a little after application and then there is loads of slack when I next pull the brake lever. Overall the stopping power is pitiful. I thought about adding a spring to the cable to force the actuator arm back to the start position. I removed the actuator arm this afternoon and noticed that the further in the actuator arm is the less spring back there is. Since the circlip positions the arm I thought that if I added a copper shim next to the disc pad this might position the actuator tight up against the circlip and then allow the arm to fully return to the "off" position.
Any advice?
Any advice?
