torque wrench.
torque wrench.
Postby martyn dwane » Fri Aug 16, 2024 11:41 am
I have two torque wrenches at present 3/8"sq & 1/2"sq drive that cover all the higher torque settings needed for a Lambretta ,Im looking for a 1/4" sq drive to cover the lower settings, any recommendations please.
TIA
martyn dwane
Re: torque wrench.
Postby Toddy » Fri Aug 16, 2024 6:07 pm
I use the Halfords ones usually good quality
Re: torque wrench.
Postby nastro azzurro » Fri Aug 16, 2024 7:27 pm
Plus 1 for Halfords.
nastro azzurro
Re: torque wrench.
Postby roli150lam » Fri Aug 16, 2024 8:09 pm
+2 halfords
roli150lam
Re: torque wrench.
Postby Cgt75b » Sat Aug 17, 2024 6:12 am
+ Tool station Machine mart, Screwfix others are available.
Re: torque wrench.
Postby bookertmgs1 » Mon Aug 19, 2024 3:16 pm
+3 for Halfords
With a 3/8th & 1/2" - you should be covered anyway.
For anything below that you should be able to guage with your hand - it just needs to be tight - not swinging off a 5' extention bar tight.
bookertmgs1
Re: torque wrench.
Postby ULC Soulagent » Tue Aug 20, 2024 9:50 am
Halford +4
Re: torque wrench.
Postby Leotech » Wed Aug 28, 2024 9:43 am
I use one for a bicycle, The kits are relatively cheap and come with a selection of Allen key and torx bits.
https://planetx.co.uk/products/jobswort ... wrench-set
Leotech
Re: torque wrench.
Postby martyn dwane » Wed Aug 28, 2024 11:25 am
thanks, last one looks spot on ,
martyn dwane
