Solid copper gasket removal
Postby jonoy » Fri Aug 02, 2024 1:26 pm
Good afternoon
Any suggestions on how to remove a solid copper exhaust gasket from exhaust stub
Originally used reinzosil on mating face.
jonoy
Re: Solid copper gasket removal
Postby jonoy » Fri Aug 02, 2024 9:36 pm
Cancel that, it seems acetone works and a bit of blunt force
jonoy
Postby gaz_powell » Tue Aug 06, 2024 9:06 pm
Is that sealant good?
heard good things so bought some, obviously not used it yet.
Postby jonoy » Tue Aug 06, 2024 11:05 pm
gaz_powell wrote:Is that sealant good?
It’s very good
jonoy
Postby bookertmgs1 » Wed Aug 07, 2024 9:10 am
It’s very good
+1 - its great stuff
Only one downside as the OP has pointed out - its so good, its difficult to seperate when you come to strip down. I had a terrible job trying to get the barrell off the base packer / casing. I'll be trying the acetone method next time.
bookertmgs1
Postby shamrockexpress » Wed Aug 07, 2024 9:41 am
whats the best paste/sealent for exhaust slip/manifold sealing???
Any recomendations.
thanks
shamrockexpress
Postby Warkton Tornado No.1 » Wed Aug 07, 2024 11:26 am
shamrockexpress wrote:whats the best paste/sealent for exhaust slip/manifold sealing???
Any recomendations.
thanks
Silicone bathroom sealant - the one that smells like vinegar. Decades of use has proven it to many of us I’m sure.
As many racers will tell you, if an engine strip is necessary between races on the day, there’s no time for allowing a sealant to go off & silicone copes.
You may just end up with what looks like some kind of distorted sex aid blasted out of the exhaust as a bonus……
Postby shamrockexpress » Wed Aug 07, 2024 2:03 pm
sounds a bit temporary does silicon, something more robust to keep exhaust joints sealed.
i use several silicons at work and wouldnt trust them to seal with excessive heat.
I do stand to be corrected hence the reason im seeking advice.
thanks for now
shamrockexpress
Postby Warkton Tornado No.1 » Thu Aug 08, 2024 1:55 am
shamrockexpress wrote:sounds a bit temporary does silicon, something more robust to keep exhaust joints sealed.
thanks for now
Just try setting silicone alight. Bearing in mind that glass has silicone as one of it’s components & that the electrical sleeving @ the business end of anything designed to get hot - such as hot air guns etc - is silicone, then you might consider differently…..
One product that I have had fail is Blue Hylomar ‘as recommended by Roll Royce’ which is more akin to blue snot.
I’ve used the bathroom silicone sealant on road exhausts & never had a problem.
Anyway, you asked & there you have my recommendation.
Postby shamrockexpress » Thu Aug 08, 2024 10:32 am
thanks for the advice, fair enough it will cost nothing to give it a go !!!!!!
regards Damian
shamrockexpress
