New member - Jet 200
Postby Pablo » Tue Jun 11, 2024 8:50 pm
Hello all, first post . Bought a Jet 200 about 3 years ago and I’m just getting round to getting it back on the road!!! It’s the first Lambretta ( Servetta) I’ve owned, I’ve had 6 PXs , a T5 , a couple of LMLs and a 50 special small frame over the years so I’m not new to geared 2T scooters. I’m going to keep this scooter as original as possible so will aim to re use most of the parts if possible, I’m not even going to paint it , it’s got light surface rust but it’s pretty solid . At the moment the engine is out and stripped, I’ve yet to start on the frame and electrics . I’ve noticed a couple of cracks in the engine case around the gear cluster bearing race . When I’ve figured out how to post pics I’ll post the pic of the case . I’m hoping it can be welded and would appreciate some expert opinions ;)
Pablo
Re: New member - Jet 200
Postby gp200ts1 » Tue Jun 11, 2024 10:44 pm
Fingers crossed the cracks are just casting marks.
gp200ts1
Postby Fast n Furious » Tue Jun 11, 2024 11:45 pm
gp200ts1 wrote:Fingers crossed the cracks are just casting marks.
+1
Postby Pablo » Wed Jun 12, 2024 8:07 am
I’m convinced they’re cracks , one of them is still visible on the casing where the gear cluster has slightly worn the casing away , surely a casting mark would’ve been worn off by this ?
Still trying to figure out how to post pics :?:
Pablo
Postby dickie » Wed Jun 12, 2024 8:15 am
I use postimg.cc. it's pretty easy to use.
As others have said, it's an unusual place for a crack, but what you say about the cluster wearing it also makes sense. If you mean where I think you mean, the gear cluster should be pulled away from there anyway when the clutch is fitted. We need photos really.
Postby LambrettaMarky » Wed Jun 12, 2024 9:15 am
Welcome. I use Flickr on the PC for posting pics..
LambrettaMarky
Postby Pablo » Wed Jun 12, 2024 9:34 am
I’ve not got a computer, do everything on my phone , I’ll get my daughter to try to add a few pics later .
Pablo
Postby Covboy » Wed Jun 12, 2024 9:40 am
i use postimage from my phone - just upload the pics to your post image account and cut and paste the urls of teh pic into the LCGB chat
Postby LambrettaMarky » Wed Jun 12, 2024 9:46 am
Tapatalk is a great way to access a forum & post pics. There is quite possibly a good reason why it's not already, but to have this forum on Tapatalk would be good..
LambrettaMarky
Postby Pablo » Wed Jun 12, 2024 7:24 pm
[url][/url]
Pablo
Postby Pablo » Wed Jun 12, 2024 7:26 pm
I give up , can’t post pics from my phone ,
Pablo
Postby Pablo » Wed Jun 12, 2024 7:43 pm
https://www.flickr.com/photos/200861882 ... 8S3krap3TZ
Haha!! I’ve done it , these are various images of the same cracks in different light , can anyone advise if this case is still usable, ie can it be welded ?
Pablo
Postby Pablo » Wed Jun 12, 2024 8:46 pm
https://flic.kr/p/2pWWgj6
On this image you can see one of the cracks is still visible under the wear marks from the gear cluster
Pablo
Postby dickie » Thu Jun 13, 2024 8:21 am
I don't think they're cracks after all. Have any of them gone through to the other side of the casting?
If you want to put your mind at ease, just dremel into them with a stone.
Postby LambrettaMarky » Thu Jun 13, 2024 9:49 am
Get a bit of 240 grit wet n dry on there and see if you can remove them perhaps. If you can they're not cracks. Could be innocuous flow lines from the casting process perhaps.
LambrettaMarky
Postby Pablo » Thu Jun 13, 2024 4:53 pm
https://flic.kr/p/2pX8wzB
Crack seems to have gone , you can still see it at either end but it’s gone in the middle, I’m just going to carry on with re building the engine using this casing , it’s going to standard so won’t be overly stressed , thanks for the comments I’ll post again soon when it’s up and running
Pablo
