simple wiring question
1963 s2 Li125
so i am building this scooter, no battery, no indicators and i am told that the closest wiring diagram in Sticky (3rd ed) is page 323. this seems to make sense.
i have loom with grey, green brown and black, then red and grey brake pedal. brown and white horn
so i have wired it as follows:
headset >> junction block >> loom
green killswitch>>block>>green loom
brown horn >>block>>brown loom
black speedo bulb>>block>>black loom
lightswitch:
white to horn
red/blue direct to headlight
orange to block >>brown (is brown the power feed?)
and headlight earth to somewhere? direct to earth or via the block?
so i have a spare grey loom wire (from footbrake?) on the block,
and i know soemthing has to be earthed on the control rod housing.
must be an easy fix right?
John
lightswitch:
white to horn
John
