gizmo wrote:Are the top two threads on a horncasting deep enough to fit a Heli coil.
Nice one Thanks Toddy. Just ordered some.Toddy wrote:gizmo wrote:Are the top two threads on a horncasting deep enough to fit a Heli coil.
Yes you can get different length helicoils though
+1Toddy wrote:gizmo wrote:Are the top two threads on a horncasting deep enough to fit a Heli coil.
LambrettaMarky wrote:Something I tend to do nowadays with any helicoil and especially so when they're into ally, is to soak the helicoil in thread lock (Green, so a strong one) & then run a tap through it when it's had time to dry.
Should last pretty much forever then.
You can also stack them so having shorter ones is generally a good idea as shortening a longer helicoil can leave a sharp edge at the top.
Users browsing this forum: Google [Bot] and 83 guests
