Extended fuel tank
Extended fuel tank
Postby gp200ts1 » Fri May 03, 2024 1:21 pm
Looking at a 14 litre tank but the seller states that it is for series 3/gp. How much different is a series 1/2 regards to space to fit?
gp200ts1
Re: Extended fuel tank
Postby bookertmgs1 » Fri May 03, 2024 1:42 pm
if you search for Mid Range tank you should see various threads on the pros/cons
bookertmgs1
Postby Toddy » Fri May 03, 2024 6:57 pm
gp200ts1 wrote:Looking at a 14 litre tank but the seller states that it is for series 3/gp. How much different is a series 1/2 regards to space to fit?
I’ve fitted the bolt in one into a series 2 fitted fine after struggling to get the strap type mid range to fit , the SSP one which is discontinued now always fitted in all series 1/2/3
