5 plate clutch
5 plate clutch
Postby jonno » Sat Mar 02, 2024 6:00 pm
I have a 5 plate clutch,original style. Does anyone know what the 5 cork plate thickness should be to determine wear ? Thanks
jonno
Re: 5 plate clutch
Postby gaz_powell » Sun Mar 03, 2024 9:38 am
Mine is made up with 2.60mm corks and 1.5mm steels
Re: 5 plate clutch
Postby dickie » Sun Mar 03, 2024 7:56 pm
It's difficult to state an absolute minimum as 5 plate clutches are all different.
For example, if you use different steels, then the minimum thickness varies. The same is true if you use different springs, different gearbox or your motor produces different torque.
So the best way to tell, in my opinion, is that if it slips under load up and incline, they're goosed.
Sorry for half-arsed answer.
Re: 5 plate clutch
Postby jonno » Mon Mar 04, 2024 11:09 pm
Thanks for the replies. The surflex logo embossed on the corks is really crisp, no wear, so thats what Im judging them by, in good knick. :D
jonno
Re: 5 plate clutch
Postby hullygully » Tue Mar 05, 2024 10:36 am
when I check mine I refer to the old method of if a 13mm open ended spanner fits over the combined cork plates only then bin 'em, but prefer a 14mm, if that's slack then bin or replace
Re: 5 plate clutch
Postby gaz_powell » Tue Mar 05, 2024 9:21 pm
Ive got a green/grey coloured 5 plate set of steels and corks made by Surflex sat in a bag never used it.
Will measure them but im not home until Friday
