Fork setup
Fork setup
Postby Solid Air » Tue Jan 09, 2024 10:08 pm
I'm thinking of building some forks with external suspension / damper units. Anyone done this that can offer tips, feedback, which units or dimensions?
Thanks, Mark
Re: Fork setup
Postby Fast n Furious » Wed Jan 10, 2024 2:15 am
A friend of mine has recently built himself a very tidy, widened, series 2 special with a 400 Burgman auto engine.
He widened the fork loop to accommodate the front wheel, links, brakes and suspension from a Scomadi.
Handles very well.
Re: Fork setup
Postby Knowledge » Wed Jan 10, 2024 8:57 pm
Scooter Restorations has the Indian external suspension forks for sale at a very reasonable price recently, but there are no fork links available, so that explains the cost of the cheap forks.
All the same, it might be worth a punt Mark
Re: Fork setup
Postby Solid Air » Wed Jan 10, 2024 9:37 pm
Thanks FnF.
Martin, yes a very reasonable price. Would like to be able to use an anti-dive setup too, so not sure these would work even if I could find links?
Anybody used the Protech front dampers?
Re: Fork setup
Postby gaz_powell » Thu Jan 11, 2024 10:03 pm
Speak to Scotty at DSC, they were using the Protech on the track
Re: Fork setup
Postby Solid Air » Thu Jan 11, 2024 11:31 pm
Cheers Gaz, will do
Re: Fork setup
Postby ULC Soulagent » Fri Jan 12, 2024 11:54 am
SA2 has protech front dampers ;)
