Page 1 of 2
Lighter/ Easier Clutch Solutions for Hand injury
PostPosted: Tue Jan 09, 2024 6:59 pm
by scarkey
Hi,
I am currently recovering from a broken left hand, grip is not so good.
I am looking at solutions to make the use of the clutch easier eg AF Rayspeed Easy Clutch etc.
What have others used as a answer to this problem
TIA
Clarkie
York SC
Re: Lighter/ Easier Clutch Solutions for Hand injury
PostPosted: Tue Jan 09, 2024 9:57 pm
by Storkfoot
I can vouch for this Chiselspeed conversion. I have it on an LTH 7 plate and the clutch is as soft as on my standard TV175. It’s not cheap but it works.
https://www.chiselspeed.co.uk/store/product/CST845465B
I tried the AF easy clutch but gave up. It made the difference between a slipping clutch and a dragging clutch to be almost non existent. I could probably have persisted with every available permutation but I lost patience and took it off.
PostPosted: Wed Jan 10, 2024 10:18 am
by Tractorman
I have a LTH 7 plate clutch in the sidecar engine and Martin at Chiselspeed recommended using standard springs in the clutch when I mention the clutch was stiff to use. I did so and it is much easier and up to now as worked fine.
PostPosted: Wed Jan 10, 2024 3:39 pm
by Norrie Bodge
AFs UNI easy-clutch
Paired with the AF cassette
Works well on TS-230
PostPosted: Wed Jan 10, 2024 7:53 pm
by Rich Oswald
Storkfoot wrote:I can vouch for this Chiselspeed conversion. I have it on an LTH 7 plate and the clutch is as soft as on my standard TV175. It’s not cheap but it works.
I've tried both and the Chiselspeed was by far the best option. The dearest but the best. That's not to say that the AF didn't work because it did. I tried the AF on a st'd clutch with MB springs at first, this was despite most people saying it doesn't work with st'd clutches but it did help. I then tried it with an AF Road cassette which was an improvement again but still not as good as the Chiselspeed.
PostPosted: Sun Jan 21, 2024 9:52 am
by Cgt75b
scarkey wrote:Hi,
TIA
Clarkie
York SC
Have you tried Derek Dowlings easy clutch?
PostPosted: Sun Jan 21, 2024 10:56 am
by Toot
I'd definitely recommend this option, arguably one of the most practical conversions available for a Lambretta engine. Especially anyone (like me) now suffering with aching hands/fingers from many years of winter riding when I was younger.
I fitted my conversion before riding to the Euro in Poland and it made the journey an absolute pleasure. I'll definitely get this done for any other 'performance' engines with an up rated clutch. (I have an AF Race Clutch in my TS1). I can pull in the clutch lever with one finger now.
PostPosted: Sun Jan 21, 2024 12:42 pm
by Den08
After two Brocken fingers and wrist screws plate etc thought that’s it for me.
Rb250 Af uni easy clutch with Lth clutch new sip clutch cable, two finger clutch now absolutely
Spot on, best of luck for your recovery.
PostPosted: Sun Jan 21, 2024 1:18 pm
by Storkfoot
Den08 wrote:After two Brocken fingers and wrist screws plate etc thought that’s it for me.
On the AF Easi Clutch, what notch did you use for the clutch cable trunnion?
PostPosted: Sun Jan 21, 2024 2:22 pm
by trotsky
Cgt75b wrote:
scarkey wrote:Hi,
TIA
Clarkie
York SC
Agreed. Would definately recommend. Just put one on Wendy's TS1....superb bit of kit. ;)
PostPosted: Sun Jan 21, 2024 4:12 pm
by Den08
Tbh i used the original clutch arm, the uni arm didn’t sit to well on the uni spline’s sod the fetling as
as it is all interchangeable it’s only the rack and pinion that makes the difference anyway and it does it really well.
PostPosted: Mon Jan 22, 2024 11:52 am
by Rich Oswald
trotsky wrote:
Cgt75b wrote:
scarkey wrote:Hi,
TIA
Clarkie
York SC
Hi Steve, I've heard a lot of negative feedback about these. Some say it reduces the adjustment between Clutch slip and Clutch drag massively and they have taken them off.
PostPosted: Mon Jan 22, 2024 11:54 am
by Rich Oswald
Paul, I used the notch nearest the tyre, so in theory I could go back to the st'd Innocenti clutch arm also.
PostPosted: Mon Jan 22, 2024 6:16 pm
by Storkfoot
I did the same too, Rich. Anyway, I no longer have the Easi Clutch. I was just curious as to whether it was set to one of the notches nearer the pivot of the lever.
PostPosted: Mon Jan 22, 2024 9:07 pm
by trotsky
Hi Rich,
Strange? We tried the AF set up & i couldn't get to work at all, but with Derek's Mk4 version no probs, i measured it before & after & it has the same cable travel with the same clutch & dogleg lever, just a quite noticeable lighter feel at the lever?
Weeksey has one on, which seem's to work great, so that's what prompted us to try one on Wendys... tho not rallied it yet for a proper testing, so far so good. :?:
PostPosted: Tue Jan 23, 2024 11:40 am
by Rich Oswald
trotsky wrote:Hi Rich,
Steve, i'm not knocking it as i've not tried one but just going on what's been reported.
PostPosted: Tue Jan 23, 2024 4:08 pm
by scarkey
Thanks to all who replied to this Post.
Plenty to think about while trying to build the grip in my hand back.
Best Wishes
Steve "Clarkie" Clark
York SC
PostPosted: Tue Jan 23, 2024 4:55 pm
by alex_hughes
I highly recommend the Chiselspeed conversion. Expensive but I’d say worth every penny.
PostPosted: Tue Jan 23, 2024 6:20 pm
by L111amo
I tried the earlier versions & couldn’t get them to work, seen the latest version, different take on it, any experts that think it work any better ?
PostPosted: Wed Jan 24, 2024 11:25 am
by Rich Oswald
L111amo wrote:I tried the earlier versions & couldn’t get them to work, seen the latest version, different take on it, any experts that think it work any better ?
I take it, this is Derek Dowling's mechanism?
