by citydaz » Wed Nov 22, 2023 10:41 pm
Hi,
Im in the final stages of my 150dl rebuild. Im having problems with the clutch arm. I have fitted a MB arm and MB spring, but with the clutch cable tight and trunion fitted, when I pull the clutch lever in the arm doesnt spring back when I then release the lever.
Any clues as to what is happening?
Engine was completely rebuilt - Im not sure if I have added the gearbox oil yet.
citydaz
by ULC Soulagent » Thu Nov 23, 2023 3:55 am
Release your clutch cable and try the arm itself by using an open ended 14 or 17 mm spanner. If it doesn’t spring back on it’s own then I’m sure it will be casing cover off and check the whole arm mechanism.
by citydaz » Thu Nov 23, 2023 10:15 pm
Thanks - looks like im going to be busy stripping down all that I have built up.
citydaz
by Knowledge » Thu Nov 23, 2023 11:39 pm
Whilst the clutch arm has a little external return spring, the job of returning the clutch arm is the principally carried out by the big springs in the middle of the clutch.
Is you clutch working when the engine is running?
by citydaz » Sun Nov 26, 2023 10:26 pm
Hi,
the engine hasnt been run for over a year when it was originally rebuilt just to test it.
I have connected the carb today, and hope top get it running next week.
Im not sure if the clutch has ever worked.?!
Cheers.
citydaz
