GP headlight and ignition switch
Postby jonoy » Fri Nov 17, 2023 8:38 pm
Good evening all
I have been connecting a MB ignition switch to my GP.
I have 3 brown wires 1 from ignition switch one from loom and 1 coming up from horn.
Only 2 brown connectors on headlamp block.
Do I need to solder 2 of these together or is there another solution.
Lambretta is 12v AC
jonoy
Re: GP headlight and ignition switch
Postby Knowledge » Sat Nov 18, 2023 8:39 am
Yes. I recommend that you ignore the original headlight connector block, cut off the bullet terminals and fit a Wago connector block for the browns. Here is a link.
https://www.screwfix.com/p/wago-222-series-32a-3-way-lever-connector-50-pack/76776
These are much more reliable than the original junction box.
In fact, I would recommend buying the variety-pack from Screwfix
https://www.screwfix.com/p/wago-basic-installer-connector-set-75-pack/48808
as this gives you lots of options for connecting two wires, three wires or more into a single connector block. It makes it very easy to install additional circuits for extra lights or accessories. Wago connectors are reusable and you can even use them for their original intention; to re-wire the house.
The wire to the horn is an earth and connects to the (usually) white wire from the light switch on the handlebar.
Postby jonoy » Sat Nov 18, 2023 4:23 pm
Iam trying to upload a photo of what I currently have but won’t allow it to be posted.
jonoy
Postby Norrie Bodge » Sat Nov 18, 2023 4:42 pm
jonoy wrote:Iam trying to upload a photo of what I currently have but won’t allow it to be posted.
Use postimage to upload your photo’s
Norrie Bodge
Postby jonoy » Sat Nov 18, 2023 8:14 pm
Image.
This is where I have got to
jonoy
Postby Norrie Bodge » Sun Nov 19, 2023 9:12 pm
Horn brown is commonly paired up to brown from headlights switch
Looking at your picture, you gotta use purple from the ignition switch with browns, use one of the triple connection options for these browns then solder in a bridge wire for the purple
GL
Norrie Bodge
Postby jonoy » Sun Nov 19, 2023 10:35 pm
I don’t have a purple
jonoy
Postby martyn dwane » Mon Nov 20, 2023 3:47 pm
see this diagram on wiring on http://www.ilambretta.co.uk/wiring.html
use the left hand 3 holes to plug all of your browns into.
martyn dwane
Postby jonoy » Thu Nov 23, 2023 6:12 pm
martyn dwane wrote:see this diagram on wiring on http://www.ilambretta.co.uk/wiring.html
Thank you for that all working.
jonoy
Users browsing this forum: Google [Bot] and 71 guests
