by Littlewheels » Sun Oct 15, 2023 5:36 pm
Ive rebored my TV cylinder to 63mm which now makes it 180cc. Does anyone know what changes I need to make to the carb settings for the increase in cc?
Everything else will be set up as standard.
Littlewheels
by Fast n Furious » Sun Oct 15, 2023 6:28 pm
You may not need to make any changes.
After the running in period has completed you could run at full throttle for a while, drop the throttle and cut the ignition, and then do a plug chop to determine if you need a richer mixture.
by Knowledge » Sun Oct 15, 2023 10:12 pm
If you look at the factory carburettor settings for the GP150 and the GP200 (same size carb - 22mm), there are very few differences between the jets. I doubt if your carb will need any changes.
Try it.
by Littlewheels » Tue Oct 17, 2023 6:34 pm
Thanks for your thoughts. Yes I think I'm gonna try it with standard settings and see how she goes.
Littlewheels
