Squish
Squish
Postby dave411 » Thu Oct 16, 2014 10:05 am
I am fitting a 150 barrell,head and piston to mt Li,will I need to check the squish clearence?
dave411
Re: Squish
Postby stonerosesmod » Thu Oct 16, 2014 12:54 pm
I would check squish on every new top end i fitted.Your looking between 1.0mm - 1.5mm ideally.
stonerosesmod
Re: Squish
Postby dave411 » Thu Oct 16, 2014 2:13 pm
Thanks,will do.
dave411
Re: Squish
Postby Captain Pugwash » Thu Oct 16, 2014 2:19 pm
Don't be too surprised if you are not able to get it below 1.5mm squish clearance because even without a head gasket fitted they rarely squish down to that clearance on standard parts.
Mark.
Captain Pugwash
Re: Squish
Postby dave411 » Thu Oct 16, 2014 9:43 pm
Ok,thanks for the info.
dave411
