Damaged Barrel
Damaged Barrel
Postby Littlewheels » Wed Jul 19, 2023 11:43 pm
I have a TV 175 cylinder with a fracture in the spigot.
Can it be welded and then machined?
Thanks.
Littlewheels
Re: Damaged Barrel
Postby hullygully » Thu Jul 20, 2023 9:34 am
how far up the spigot is the crack bud? :?
Re: Damaged Barrel
Postby Littlewheels » Thu Jul 20, 2023 6:12 pm
About 3cm?
Littlewheels
Re: Damaged Barrel
Postby Fast n Furious » Fri Jul 21, 2023 1:30 am
If the crack veers off toward the periphery of the spigot then it's probably time to change it.
If it's more or less vertical, then it probably could remain servicable by drilling a hole through the spigot at the end of the crack to relieve the stress.
Re: Damaged Barrel
Postby hullygully » Fri Jul 21, 2023 8:41 am
30mm, so that'd leave you about 25mm if you got it machined off upto the crack?
I have a TS1 barrel that's machined down cos of a cracked spigot.
the quatrini's don't have a spigot, so I'd have thought if you have 25mm of spigot then even for locating purposes its doin its job :?
