by TurboTrev » Sat Jul 01, 2023 4:04 pm
Am I right in assuming an original GP ducati 6v 6 pole stator plate will have a wider diameter hole in the centre than a late 6v 6 pole SX stator to accomodate the beefier GP crankshaft?
If so, does anyone know the internal hole diameter in each of the two stators? The spare one I have seems to be 28.7mm and I'm not sure if it's late SX or GP.
Also, does anyone know if a GP stator can be used on a late SX?
Finally, which points are best for a late SX - most dealers seem to sell EFFE (made in Italy)?
Any thoughts appreciated. Thanks.
TurboTrev
by Fast n Furious » Sat Jul 01, 2023 8:34 pm
Series 3 stators typically had 28mm holes through the middle.
GP's had 32mm holes.
by TurboTrev » Sat Jul 01, 2023 8:48 pm
Fast n Furious wrote:Series 3 stators typically had 28mm holes through the middle.
Thanks for the info. The one I have must be a Series 3, which is what I was hoping.
TurboTrev
