by Littlewheels » Thu Jun 22, 2023 6:03 pm
Which is the best method for throttle cable attachment?
Nipple on cable at pulley with thimble/screw or thimble/screw at pulley with cable nipple at carb end?
Littlewheels
by nickw » Thu Jun 22, 2023 7:24 pm
I always try and put the nipple at the carb end. I find it tricky getting the right cable length putting nipple at the top.
nickw
by Tractorman » Thu Jun 22, 2023 8:44 pm
I always put the solderless nipple at the handlebar end. It seems easy enough to set up and it makes taking the carb off a lot easier.
by Norrie Bodge » Thu Jun 22, 2023 10:59 pm
Tractorman wrote:I always put the solderless nipple at the handlebar end. It seems easy enough to set up and it makes taking the carb off a lot easier.
+1
Norrie Bodge
by hullygully » Fri Jun 23, 2023 10:25 am
+2, unless its a big carb then the nipple always goes in the slide & solderless @ the throttle
by Rich Oswald » Fri Jun 23, 2023 11:37 am
hullygully wrote:Tractorman wrote:I always put the solderless nipple at the handlebar end. It seems easy enough to set up and it makes taking the carb off a lot easier.
+3
by missing lynx » Fri Jun 23, 2023 12:28 pm
Rich Oswald wrote:hullygully wrote:Tractorman wrote:I always put the solderless nipple at the handlebar end. It seems easy enough to set up and it makes taking the carb off a lot easier.
+3
+4 to make it easier I drill a small hole in the throttle cam so the cable can pass through the nipple and out the other side
