Cush drive spring length
Postby Scooterslag » Sat Jun 03, 2023 4:28 pm
Just doing a rebuild and sorting out some bits, I've got a couple of cush-drive springs and don't know if they are S3 or the shorter S1 type, can't find any measurements so I haven't got anything to compare it to. What's is the length of the later spring? cheers Paul
Re: Cush drive spring length
Postby Scooterslag » Mon Jun 05, 2023 11:19 pm
anyone? if someone could measure the height of the spring - that would be smashing, thanks again Paul
Postby nickw » Tue Jun 06, 2023 9:15 am
Managed to get one of mine measured. 34.4 to 34.7mm if that helps
nickw
Postby Scooterslag » Tue Jun 06, 2023 12:52 pm
nickw wrote:Managed to get one of mine measured. 34.4 to 34.7mm if that helps
thanks for that, cheers Paul ;)
Postby hullygully » Tue Jun 06, 2023 5:35 pm
is that measurement with the spring compressed bud as seams a tadge small :?
Postby Cgt75b » Tue Jun 06, 2023 8:14 pm
Just for comparison
Not under any load
36.12 - 37.32
I hope that helps.
Postby Scooterslag » Tue Jun 06, 2023 8:59 pm
Cgt75b wrote:Just for comparison
Not under any load
36.12 - 37.32
I hope that helps.
Cheers , yep that's not too far off what the two springs I've got measured, thanks Paul :)
Postby nickw » Tue Jun 06, 2023 9:09 pm
hullygully wrote:is that measurement with the spring compressed bud as seams a tadge small :?
No, not under any load. Now I'm worried lol
nickw
