by Scooterslag » Wed May 17, 2023 12:07 pm
Just rebuilding a gearbox ( Italian cases and end plate) and one of the dowels isn't loose or rocking about but you can pull out with a bit of loose pressure, everything lines up out and the studs etc are all in great condition. Anything to be concerned about or good to go? thanks Paul
by hullygully » Wed May 17, 2023 5:57 pm
loctite it in place if you're worried just make sure the endplate has 2 punch marks on the outside of its hole
by Scooterslag » Wed May 17, 2023 8:44 pm
hullygully wrote:loctite it in place if you're worried just make sure the endplate has 2 punch marks on the outside of its hole
Cheers figured a blob of loctite might be the answer but always prudent to check with endplate stuff, thanks Paul
Users browsing this forum: Google [Bot] and 78 guests
