Sorry I am being super lazy, is a GP 125 inlet manifold a different size to say a LI 125, I am aware of the 200 having different hole spaces for fixing to the barrel, it is the spigot to carb I am enquiring about?
Cheers Shane.
Scooterslag wrote:You should have no problem fitting the GP/DL 125 carb and manifold to your LI150 barrel - both have the same smallblock/barrel stud spacings . Paul
shane BBoys wrote:Scooterslag wrote:You should have no problem fitting the GP/DL 125 carb and manifold to your LI150 barrel - both have the same smallblock/barrel stud spacings . Paul
Yes I am aware of that the question was the manifold to carb i was hoping to get away with not dropping the motor out wish full thinking on my part!
Cheers Shane.
hullygully wrote:are you keeping the li125 18mm carb & want to use the gp 20mm manifold?
if so then try it in the carb first, it shouldnt fit, but it could well be slightly worn & could fit
