New Rear Hub
New Rear Hub
Postby Specialcase » Fri Oct 28, 2022 4:30 pm
Good Afternoon all
I’ve got an API Rear Hub #19.0.4.5070 and it has a damage fin. I read a lot that the Indian ones were rather inferior quality. If I should replace what should it be? SIL, UNI, FIA ITALIA, SCOOTOPIA. It’s to fit onto my Q210 S3 engine.
Any hints from The gurus? WT Knowlg F&F Storky?
TIA
Spl
Specialcase
Re: New Rear Hub
Postby gizmo » Fri Oct 28, 2022 5:26 pm
Always found the Sil ones have been fine. Had no issues with the scootopia ones apart from being a bit tight with sip rims but it was easily sorted with a file.
gizmo
Re: New Rear Hub
Postby Fast n Furious » Fri Oct 28, 2022 9:46 pm
Any of those brands should be ok.
As gizmo pointed out. just make sure the rims fit well.
Any new hub should also come with a matching compression cone.
Re: New Rear Hub
Postby Storkfoot » Sat Oct 29, 2022 8:21 am
I have been using UNI since they came out. I’ll continue to use them. Of the others you mention, I only have experience of the FA Italia. UNI are more substantial and better made, or they were several years back when I last compared the two.
Re: New Rear Hub
Postby daniel whiteley » Sat Oct 29, 2022 1:46 pm
I’ve got a scootopia one in the shed that I’ve never fitted if your interested
daniel whiteley
Re: New Rear Hub
Postby ULC Soulagent » Sat Oct 29, 2022 2:25 pm
daniel whiteley wrote:I’ve got a scootopia one in the shed that I’ve never fitted if your interested
Good hub especially if it’s the super safe type they use too sell
Re: New Rear Hub
Postby daniel whiteley » Sat Oct 29, 2022 3:13 pm
Yeah I think it is , prob bought it around 8 years ago I’d forgot all about it , just been sat in the box
daniel whiteley
Re: New Rear Hub
Postby Specialcase » Mon Oct 31, 2022 7:39 pm
Hi Daniel
Tried to pm 3 times, but no going thru. Can you pm me and hopefully I can answer you?
Spl
Specialcase
Re: New Rear Hub
Postby daniel whiteley » Tue Nov 01, 2022 9:38 am
Specialcase wrote:Hi Daniel
Spl
Morning , I got a pm and replied , I will try to get over to my mums where it is and get some info for you , if you forward me your number I can send some pics
daniel whiteley
Re: New Rear Hub
Postby daniel whiteley » Tue Nov 01, 2022 7:18 pm
Email sent special case
daniel whiteley
