Strange Clicking - Spanish 150 Special
Postby Bobf » Wed Sep 28, 2022 8:07 am
Hi All
I am refurbishing a 1969 Spanish Series 3 Li 150 Special. All is going quite well. However, checking the gearbox side I decided that there was no need to strip the gears, but replaced the clutch. On the hub side, new hub, brakes and layshaft oil seal.
Hear is the problem when I rotate the hub in neutral there is an audible clicking sound, in forward and reverse directions. I have checked all obvious areas such as kickstart binding, breaks etc. The clicking is there with hub on or off. No keen to strip the gears down unless I have to but will be guided by the more experienced.
So, any suggestions? on what it might be? As the scooter has been laid-up for many years the wheel bearing may be the problem, but it rotates freely and has no discernable play.
I do have an audio file of the clicking but cannot seem to attach it to this posting (maybe I am doing something wrong).
All advice appreciated.
Bobf
Bobf
Re: Strange Clicking - Spanish 150 Special
Postby hullygully » Wed Sep 28, 2022 12:21 pm
did you have any play on the 1st gear?
Postby Bobf » Wed Sep 28, 2022 1:48 pm
Hi Not as far as I can see. The clicking does appear to be at the bearing side.
Bobf
Users browsing this forum: Google [Bot] and 63 guests
