Is a series 2 frame the same as series 3 in that all three struts should line up?
dickie wrote:I've just re fitted my legshields or I'd check. But they must do, because the floor and footboards are in line and they all have the same thickness rubber underneath.
coaster wrote:I take it yours arent level then Paul?
Storkfoot wrote:I thought the front strut rubber washers were thicker like on a Vega. Is that not the case?
vegansydney wrote:Storkfoot wrote:I thought the front strut rubber washers were thicker like on a Vega. Is that not the case?
The front strut rubber buffers are approximately ~8mm thick. As far as I know no one makes them. There are good pictures in Scooter Nova #26 of Dean Orton making a set for a TV/2 rustoration.
Storkfoot wrote:
Thanks for that. I have just read the article and, yes, according to Dean, the two thicknesses originally were 3mm and 8mm at the front. I suspect I must have just doubled up on the remade 4mm ones when I rebuilt the Spanish S2.
This gets me back to the original question as to whether the struts should be in line. I now suspect not.
