Quick question as I'm trying to find out if my forks are straight before spraying them (AGAIN
Now for the question.....if your forks are bent do they bend inside the frame tube or can they bend in other places too??
cheers peeps
Storkfoot wrote:Holding a steel rule against the stem (move it around the circumference) will give you a pretty good idea. Watch for differing distances above the “crumple zone” in particular. If they were really badly out, you may well be able to see witness marks around the bottom of the stem.
I have a set at the moment that are ever so slightly out. I am going to take them to a jig to check properly.
Storkfoot wrote:The crumple zone, well that’s what I call it, as about 6” up the stem. It is where the stem is at its narrowest![]()
HxPaul wrote:Go to Mike Phoenix they do fork straitening. They have a jig.Its in Manchester.
