Oiltek long range tank + OMG tap with sender for SIP speedo?
Postby matthew » Wed Jun 22, 2022 3:12 pm
I realise it's possibly a bit of a niche question however I know Oiltek long range tanks are pretty popular, and so are SIP speedos so it's very probable that there are quite a few folks on here other than me running this combination on their scooters. Can anyone tell me how much fuel is remaining in the tank at the point when the sender triggers the 'FUEL' alert on the SIP speedo?
Thanks,
Matt
matthew
Re: Oiltek long range tank + OMG tap with sender for SIP spe
Postby coaster » Thu Jun 23, 2022 12:37 am
I have a Diablo tank on my scooter with the SIP speedo, that hold about 13 or 14 litres and the Fuel message flashes up when its down to about 4 or 5 litres. The sender is calibrated for a standard size tank
Postby matthew » Thu Jun 23, 2022 11:24 am
coaster wrote:I have a Diablo tank on my scooter with the SIP speedo, that hold about 13 or 14 litres and the Fuel message flashes up when its down to about 4 or 5 litres. The sender is calibrated for a standard size tank
Thanks Coaster!
matthew
Postby coaster » Thu Jun 23, 2022 5:28 pm
Thanks Coaster!
I shoul point out that the Oiltech tank is very similar to the Diablo tank, the main difference being that they are made of steel plate rather than ally
Postby matthew » Fri Jun 24, 2022 11:18 am
Yes, I think design-wise (and capacity-wise) they're pretty comparable, just as you say, one's steel and the other's alley. Thanks for your advice!
matthew
