Fork stem thread
Can anyone please tell me what size and pitch the thread is on a series 3/gp lambretta fork stem?
https://ilambretta.co.uk/forum/
Warkton Tornado No.1 wrote:If you mean the large thread - which seems likely - a commercially available bearing lock nut (SKF KM series) KM6 has the correct (identical) thread which is M30 x 1.5.
I have used them in the past with the matching lock-washers, but care must be taken in avoiding anything snagging on the castellated tags. For making a thread dressing tool, they would be ideal...
gaz_powell wrote:M10x1.5 (x35mm long bolt) if memory serves me
AL BARKER wrote:Following the top tapered bearings use, been looking myself but can't find tapered bearing small enough.. assuming you will have to machine top cup to hold bearing and possibly a shim to fit between stem and race??
