Warkton Tornado No.1 wrote::
To - hopefully - conclude, new chains are tight & do often require that both sprockets are slid into place in parallel, so I doubt yours are badly worn. Not unless there is an extra tooth in there somewhere. Quite why the new top tensioner can run into the clutch sprocket is a concern to my mind. It's almost as if somebody has sold you something not quite fit for purpose, an event unheard of in Lambretta remanufactured product sales.....![]()
I'd suggest that having got this far (BTW. Well done!) & sussed out the misalignment & bought into the tooling, you trim the new top tensioner to obviate the clash & fit it with some means of additional strengthener beneath/on top (I've lost the plot!) & try that. Seriously, there is a 'safety factor' even here with a humble chain drive. Whatever you have new is likely to be many times stronger than the OEM tensioners so any risk of catastrophe is low. The new chain will bed in, so any whirring noise should diminish so that it sounds less like a V*sp@. If it does: CHAMPAGNE! That is, until the realisation that the chain will need tensioning a tad more. Good job you got them tools....
srx600 wrote:
I dont really want to strip it down again just yet, how many miles do you think it will need to settle in and quieten down ?.
srx600 wrote:
for the time being I am going to put the old chain back so I can at least use it
So, I am a bit confused now as to which chain is in. New or old?
Warkton Tornado No.1 wrote:Having thought about any issues some more, I really should have empathised just why it is that the strong uprated top only tensioners exist. If you think about the ACW direction of travel, the lower run is constantly under tension except upon deceleration, where even racers will attempt to use everything available to retard the machine in any way possible. Brakes, gearbox & sitting up are all utilised in an attempt to slow the machine as drastically as possible prior to the next corner. Yet, somehow, the re-engineered alloy/nylon top tensioners cope under load extremely well despite the transmission chain loading reverting to the lower run in such instances. Having wandered around the pits & observed many fellow racers' engine strips over many years, I cannot recall seeing anything but the type I speak of. That's not to say there's not somebody using bottom chain tensioners in a race machine, but I very much doubt it......![]()
Like anything associated with raising the overall performance of Lambretta, the uprated tensioners evolved & the first commonly available type was a cast alloy reinforcement that fitted 'beneath' the OEM top tensioner to stop it bending under the load of hard deceleration through the gearbox. Thankfully, the next logical iteration was the alloy/nylon top tensioners that have proved virtually bombproof. I am aware of the moulded nylon (only) top tensioners but that wouldn't be my choice for a hard ridden machine. In fact, whenever they have appeared on a bike that I have worked on, I always add some means of extra support, usually fashioned from a piece of Unistrut just to avoid any problems. Yes, sometimes I worry too much....![]()
As for your latest acquisitions, my thoughts about any necessity for a lower chain guide have hopefully been explained, but what we do to our Lambrettas is very much a personal choice, which I applaud. You just won't find any machine of mine with disc brake windows or handlebar tassels.....![]()
Storkfoot wrote:
What issue do you have with disc brake windows, WT?
Users browsing this forum: Baidu [Spider] and 78 guests
