by Scooterslag » Thu Apr 28, 2022 9:35 am
Recently picked up a good Innocenti SX/GP 150 top end and original Borgo piston. However didn't come with a gudgeon pin. Not a problem as I have a couple of decent examples to choose from. Problem is all of them are mega-tight to the point of not even being able to get the pin in the piston at all. Any tips to help this? don't want to go bonkers and try and grind/rub etc and bugger it up when there might be a more accurate and effective way of doing this? Thanks Paul
by hullygully » Thu Apr 28, 2022 11:16 am
heat?
by Scooterslag » Thu Apr 28, 2022 11:27 am
hullygully wrote:heat?
Maybe but I'd like there to be a little more insertion ( oo er
) with the pin.
by hullygully » Thu Apr 28, 2022 3:05 pm
Jap pistons & Wossner have a lot of slack re-gudgeons, but original pistons were allways a tw*t, just heat the piston up bud
by Tractorman » Thu Apr 28, 2022 3:33 pm
Only needs a quick blast with a hot air gun.
by Scooterslag » Thu Apr 28, 2022 3:53 pm
Cheers fella's - yeah fitted tight pins before with heat but none quite as tight as this one. Its not going to be assembled at the mo- I'm just giving it a once over. Cheers Paul
by Fast n Furious » Fri Apr 29, 2022 11:58 pm
Yep... a hot piston and a freezered gudgeon pin. Always a bit easier to assemble if the cylinder studs are removed.
