Front Damper Brackets Slipping Down
Postby GExS » Sat Apr 09, 2022 7:06 pm
Any idea on how to stop the bolt on brackets slipping down? I tried tape but they still slip.
GExS
Re: Front Damper Brackets Slipping Down
Postby Tractorman » Sat Apr 09, 2022 7:33 pm
Not sure what your brackets are like but if there is enough metal to drill and tap a hole you could fit a grubscrew to help lock the in place.
Postby GExS » Sat Apr 09, 2022 8:59 pm
^ thanks. I was also wondering about getting some strips of rubber instead of regular Electricians tape wrapped around the fork tube and the clips over that. I would think others have had the same problem. I appreciate the BGM ones and their Knock offs are better, but I already have the traditional top shock bolt on brackets.
GExS
Postby Scooterslag » Sun Apr 10, 2022 2:11 pm
I used old inner tube rubber cut to fit inside the bracket - works well for me. Paul ;)
