front damper advice
front damper advice
Postby rumiman » Mon Apr 04, 2022 9:11 pm
for a non lambretta "moto rumi" i am using lambretta front dampers, i am trying to find which ones have the lowest damping affect, fat escorts have been tried but are over-damping for my needs, strange request i know but i want the "shitest" ones available, thanks in advance graham fisher,
rumiman
Re: front damper advice
Postby Warkton Tornado No.1 » Fri Apr 08, 2022 12:06 pm
My thoughts are that there were conversion damper kits available once specifically for attachment via special axle nuts, rather than 175/200 damper links that should have therefore not only had greater travel but less damping affect. That said, I have only ever seen them fitted once so conclude that they are rarer than an honest Tory.....
However.......most of us have surely encountered dampers that have failed & dismantled them purely out of curiosity, or is it just me? :!: Rheotorical question, as I do know of a guy that repaired a pair by managing to fix leaking seals.
In which case, with care, I reckon a pair of dampers can be refurbished which also allows for a change in oil weight, in your case the choice being a lighter grade.
Postby Leotech » Fri Apr 08, 2022 12:45 pm
I've got some old ones with no oil in........ they have really low damping effect.
Leotech
