disc brake bearings
disc brake bearings
Postby alex_hughes » Sun Feb 20, 2022 8:42 pm
Hi
I'm rebuilding a standard disc brake.
These days I seem much more concerned with doing things in the right order compared to when I was younger. It's an age thing I guess.
So, outer bearing in first? or inner bearing in first?
And presumably both bearings don't go fully home, since then the distance piece seems to be too long? So one fully home and the other just pushed in to suit?
Alex
alex_hughes
Re: disc brake bearings
Postby hullygully » Mon Feb 21, 2022 10:59 am
put the outside one in first, then circlip, then pack with grease, then the spacer tube, then the inner one
Postby alex_hughes » Mon Feb 21, 2022 12:01 pm
Thanks for that, really appreciate your help.
I had looked on youtube and there are two different rebuild videos which say the opposite to each other...
alex_hughes
Postby hullygully » Mon Feb 21, 2022 2:03 pm
but make sure the speedo drive is in place first!!!!!!!!!!!!!
Users browsing this forum: No registered users and 83 guests
