Hi,
I am trying to fit a mid range tank and straps, it is very tight up against the tool box.
While fitting the straps there isn’t enough room for the rubbers, can I fit the rubbers elsewhere or is there another solution?.
AL
bookertmgs1 wrote:think there has been a seperate thread about this if you use the search button.
Some frames differ & some lips on the front of the tank vary in width - which can make fitting a real struggle.
