Side panels
Side panels
Postby Cgt75b » Sun Dec 12, 2021 1:44 pm
Hi
Has anyone used the remade panels from Buzzsolomoto and the like, how do they fit and sit on the scooter?
Any feedback would be appreciated please.
Cgt75b.
Re: Side panels
Postby tim_mason » Sun Dec 12, 2021 5:34 pm
The series 1 or 2 bare metal panels are too short and leave a larger than standard gap between rear runner and bottom of panel ,
i learnt the hard way !!
tim_mason
Re: Side panels
Postby dickie » Sun Dec 12, 2021 6:44 pm
Sean burns got me some from buzz that he sent back because they were "all wrong". I've no idea what the issue was but there obviously was one. The replacement set were perfect. This was for a LI special.
I've since used another set for a regular series 3 LI, again from Buzz which were spot on.
I guess the message is that they are inconsistent but can be good. As the Mr Loaf says, "2 out of 3 ain't bad"
Re: Side panels
Postby Toddy » Sun Dec 12, 2021 8:22 pm
I’ve used two sets of pressed steel ones from Buzz series 1/2 fit , both fitted fine with correct gaps one set in 2019 one earlier this year
Re: Side panels
Postby Cgt75b » Tue Dec 14, 2021 8:02 pm
Thanks very much for the advice gents, very much appreciated, btw it’s the special ones I’m after, so as Dickie
says I hope I’m lucky.
Cheers again
