Vegila speedo KM vs. MPH
Postby vegansydney » Thu Nov 18, 2021 2:30 am
Can someone please confirm that the worm drive inside a Vegila speedo is black for MPH and silver for KM?
Otherwise they're the same (except for the face plate of course!)
vegansydney
Re: Vegila speedo KM vs. MPH
Postby vegansydney » Mon Nov 22, 2021 3:01 am
Since posting a good friend and mentor has shared the following with me. I'm posting it here as it may be of use to others in the future.
KPH - Odometer wheel has flat helical teeth, drive pinion gear made from white plastic
MPH - Odometer wheel has tall straight teeth, drive pinion gear made from black steel
I think there may be some differences between early and late Veglia speedos too, so it is possible that earlier KPH speedos had a metal drive pinion.
vegansydney
Users browsing this forum: Baidu [Spider] and 90 guests
