So annoying these brettas
I had the same ,with the tube not square to the casting so pressed it out and refitted correctly with adhesive.gizmo wrote:I've had a couple of the 5 speed which have been tight and one wasn't even square at the end. They were exchanged straight away and the replacements were spot on. Pot luck but you would think they would all be identical
Users browsing this forum: Google [Bot] and 74 guests
