Scootopia variable ignition
Postby Hammer RB230 » Tue Sep 21, 2021 12:16 pm
Hi All i have recently fitted the above to my LI RT195 after my indian stator gave up. I have fitted and timed (25 deg BTDC) as per the fitting instructions. Starting is great, however mid range to full throttle is missing badly, TDC was found by the piston stop method and the 25 BTDC using a timing disk.
Any ideas would be greatly appreciated.
Hammer RB230
Re: Scootopia variable ignition
Postby Warkton Tornado No.1 » Tue Sep 21, 2021 5:17 pm
If it's 'missing' as you say, then the strobe should have indicated that.
You have run it with a strobe to check retardation, I presume?
Postby Hammer RB230 » Tue Sep 21, 2021 7:51 pm
Yes I did strobe, I didn't notice anything wrong, might need to re check !
Hammer RB230
Postby Warkton Tornado No.1 » Wed Sep 22, 2021 12:59 am
Most strobes rely upon induction from the HT lead to flash, so it's fairly obvious if there is anything amiss. Hopefully it may just be the sparkplug, which I bet is an NGK :)
Personally, I've never known a fussier brand....
Users browsing this forum: Google [Bot] and 70 guests
