Warkton Tornado No.1 wrote:I use it only when necessary for head to cylinder sealing. Spigotting is the best sealing method & the process centralises them too, but that's not always practicable.
However, I agree that the stuff is not good for the exhaust seal.
Silicone bathroom sealant (smells like vinegar) has never failed in over 20 years.
Wombat67 wrote:Dumb question time - I'm assuming this is instead of, not as well as the copper exhaust gasket? (i've got a blown gasket to fix at the weekend so this thread is perfectly timed) Thanks
Warkton Tornado No.1 wrote:Wombat67 wrote:Dumb question time - I'm assuming this is instead of, not as well as the copper exhaust gasket? (i've got a blown gasket to fix at the weekend so this thread is perfectly timed) Thanks
Needs must & all that.....When racing, there is hardly ever the luxury of spare time. So the bathroom silicone sealant is literally spread on to the (very! Use Meths or a solvent) clean faces & the fasteners tightened up & lockwired.
That's it, with no time to allow cure or removal of excess.
Often, a grubby looking oval ring of snot will get blasted from the tailpipe. That will be the excess removed nicely![]()
Put simply, it seals brilliantly, but cannot allow for fasteners coming loose. Therefore, I just find it easier to always lockwire pre-drilled longer nuts (10 mm across flats hexagonal extension nuts created from M6 with an M7 tap run through from Toolstation) with thick, hard, plain washers. This modification is one of the best you can do to a Lambretta. Even better than whip aerials, fox tails & disc brake windows![]()
No need for a gasket (which as said previously) must be solid copper if using one. I only continue to use a gasket as it is the best way of matching the port to the flange.
I have dispensed with the gasket on occasion (Ha! When trying to obtain a Nat's more ground clearance) & the bathroom silicone sealant works just as well.
lam1962brettagg wrote:
yes all relevant for racing, but for those who bimble around with whip aerials and such like great, And I do use the wire lock nuts too!
