Headlamp Rim needed
Headlamp Rim needed
Postby GoonerKev » Thu Jun 03, 2021 1:05 pm
Anyone know where I can get hold of a "Headlamp Rim" for my Serveta Li150 series 3 1980, thought the SX type would fit but arrived this morning and doesn't. I have tried "Scooter Restorations" but no luck.
Thank you.
GoonerKev
Re: Headlamp Rim needed
Postby Fast n Furious » Thu Jun 03, 2021 1:38 pm
Buzzsolomoto is probably your best chance with spanish stuff.
Postby GoonerKev » Thu Jun 03, 2021 2:06 pm
Appreciate that, thank you
GoonerKev
Postby gaz_powell » Thu Jun 03, 2021 7:00 pm
Or Perry Lewis at Totally Scooters
Postby ToBoldlyGo » Thu Jun 03, 2021 8:41 pm
I've found that an Italian rim will fit fine. It's the headlight unit that seems to be the problem. Use an Italian headlight and it should work. I once used an SX on mine.
Postby GoonerKev » Thu Jun 03, 2021 9:18 pm
gaz_powell wrote:Or Perry Lewis at Totally Scooters
Ebay shop is blank for some reason !
GoonerKev
Postby GoonerKev » Thu Jun 03, 2021 9:19 pm
ToBoldlyGo wrote:I've found that an Italian rim will fit fine. It's the headlight unit that seems to be the problem. Use an Italian headlight and it should work. I once used an SX on mine.
Thank you ;)
GoonerKev
Postby Cgt75b » Sat Jun 05, 2021 4:36 pm
Did you get one?
Postby GoonerKev » Sat Jun 05, 2021 5:48 pm
Cgt75b wrote:Did you get one?
No, cant seem to find one, have ordered the correct headlight and fitting but no rim anywhere
GoonerKev
Postby GoonerKev » Tue Jun 08, 2021 11:49 am
All sorted, fettled the SX one to fit, just right ;)
GoonerKev
