Layshafts
Layshafts
Postby gizmo » Wed Jun 02, 2021 12:55 pm
Seeing there's a lot more options now what's people's choices for a layshaft using an Rb 20 or quattrini kit. Never had any issues with sil ones but never put this much power through one.
gizmo
Re: Layshafts
Postby ULC Soulagent » Wed Jun 02, 2021 4:22 pm
Depending on how old the lay shaft is would be a choice in changing it, although nowt wrong with Sil along with mecur,Mb’s, casa, etc etc. Just depends on how deep ur pocket is ;)
Re: Layshafts
Postby hullygully » Wed Jun 02, 2021 5:27 pm
mainly, if you're using an old one (whether Italian or Indian) check the splines for squareness, bearing faces, check the threads for the hub & mainly (IMHO) the machinists under cut (RADIUS) where the threads meet the splined section :shock:
