pipes n leeks
pipes n leeks
Postby lam1962brettagg » Tue May 11, 2021 4:44 pm
Hi all,
just had a new cylinder and exhaust fitted and getting a large amount of oil leaking from cylinder/downpipe joint.
Ive tightened the brass nuts as much as I can or dare seems to be worse on the easier one to get to.
is this oil leak to be expected? and will it be causing an air leak?
bit concerned because its a brand new alloy cylinder and piston, so running it in at the mo.
any advice welcome.
cheers
Last edited by lam1962brettagg on Tue May 11, 2021 8:14 pm, edited 1 time in total.
lam1962brettagg
Re: pipes n leeks
Postby Storkfoot » Tue May 11, 2021 7:38 pm
No, that is not right and it will be causing an air leak. Any chance of you uploading a picture?
Re: pipes n leeks
Postby lam1962brettagg » Tue May 11, 2021 7:57 pm
Hi thanks for getting back to me.
tried to but kept telling me file size too big and cant resize file size on phone.
lam1962brettagg
Re: pipes n leeks
Postby Storkfoot » Tue May 11, 2021 8:01 pm
Read your PMs ;)
Re: pipes n leeks
Postby lam1962brettagg » Tue May 11, 2021 8:06 pm
there ya go, did it.
hope that helps
lam1962brettagg
Re: pipes n leeks
Postby Storkfoot » Tue May 11, 2021 8:39 pm
Take the exhaust off, noting whether one or more of the mounting points is pulling it away from the exhaust manifold. Make a specific mental note of where, ie. which side, the leak is coming from. Is the mating surface on the exhaust flat?
Re: pipes n leeks
Postby Warkton Tornado No.1 » Tue May 11, 2021 10:58 pm
The subject has been extensively covered before, but currently Danbretta is going through a similar issue.
You must have missed his Post, so it would be best you catch up here:
viewtopic.php?f=10&t=13860
Re: pipes n leeks
Postby Meds » Wed May 12, 2021 8:20 am
What you take the manifold off check that it’s flat.
Meds
Re: pipes n leeks
Postby lam1962brettagg » Wed May 12, 2021 8:27 am
Thanks for the link, i'll take a look.
cheers
lam1962brettagg
