AF 5 speed
AF 5 speed
Postby 515paul » Thu Apr 08, 2021 9:04 am
hi
have just fitted a AF 5 Speed Gearbox, there is a slight clicking I have traced this to the 5th gear clicking on the layshaft, I know that all the gears line up, what I did was remove the layshaft fitted it to the end plate with the correct shim and the gear cluster, everything spot on,
the clicking only happens when you spin the rear wheel and not when you spin box using the clutch
515paul
Re: AF 5 speed
Postby Bogie » Thu Apr 08, 2021 7:48 pm
put your first 4 gears on the layshaft with the selector in neutral , then spin 2nd gear and make sure that it does not catch the selector which causes a clicking sound.
ive had this a few times fitting these boxes.
Bogie
Re: AF 5 speed
Postby hullygully » Fri Apr 09, 2021 3:57 pm
did you trim the wishbone & casing to suit also bud?
Re: AF 5 speed
Postby Bogie » Fri Apr 09, 2021 6:39 pm
yes i always gring the wishbone just enough so when in 5th i can get a 0.5mm feeler gauge in between the casing and wishbone
Bogie
Re: AF 5 speed
Postby 515paul » Sat Apr 10, 2021 10:04 am
morning chaps
wishbone is all trimmed down and plenty of room, if I just put the 5th gear on the layshaft and push it slightly you can feel it clicking against the brand new BGM layshaft,
and doesn't do it when I put the old 4 speed box in.
Paul
515paul
Re: AF 5 speed
Postby Warkton Tornado No.1 » Sat Apr 10, 2021 3:13 pm
Try the old OEM layshaft.
I keep banging on about the fact that OEM items were made to a standard that it's doubtful any Tom, Dick, Harry or Mark can match. Even genuine SIL layshafts are up to critical standards.....
Users browsing this forum: No registered users and 86 guests
