MB Electronic ignition mounting bracket kit, Series 3,
Postby Specialcase » Tue Mar 30, 2021 6:53 pm
Hi all
Just bought an MB Elec IGN Mount Kit Anyone got a picture of how it’s fitted?
TIA
Spl
Specialcase
Re: MB Electronic ignition mounting bracket kit, Series 3,
Postby gaz_powell » Sat Apr 03, 2021 9:57 am
Is it the two piece cast Ali one?
Both brackets go on the frame tube approx under the rear frame grille/badge holder
The cdi bracket goes on the kickstart side and the regulator on the flywheel.
There are bolts to pass through the frame and connect both pieces
I think the kit is set up for Italian GP and matches the existing holes.
Depending on what you are fitting to you may need new hole(s) driling
Postby Specialcase » Sat Apr 03, 2021 8:33 pm
Thanks gaz
I thought it was a “one size fits all” Great piece of kit - feels like it’s built out of Anvils! Anyway I’m gonna change it for the VAPE set up. No point in buying something that you have to completely rebuild.
Specialcase
Users browsing this forum: Google [Bot] and 64 guests
